  • Online today: 2,399
  • Guests: 1507
  • Total: 1507
1977 Pinto Project
Started by jlouis707, September 19, 2019, 05:19:51 PM
PonyRider62
Wow! Very Nice!
You Did A Great Job!
Save The Ponies!
Henrius
Got to be the cleanest and prettiest engine compartment I have seen on these boards. Even beats mine by a smidgen! Can't believe those valve and cam covers have not been repainted.
1973 Pinto Runabout with upgraded 2.0 liter & 4 speed, and factory sunroof. My first car, now restored, and better than it was when it rolled off the assembly line!
jlouis707
Thank you so much.  I used just used soap and water and some diluted "purple power" cleaner on the air filter snorkel hose.  Fro the actual air cleaner housing - I just carefully buffed with polishing compound - I did not go to abrasive because i did not want to change the appearance from the original brushed finish to a too shiny finish.   I was very fortunate with the car having low mileage - everything under the hood is original except the battery belts,and radiator hoses.   I also replaced the timing belt and water pump for preventive maintenance since the car is over 40 years old.
Jeff Louis
1977 Pinto Runabout
SpaceCowboy1979
Very nice looking what did you use to clean up the air filter housing
jlouis707
Thank you - I updated the post with some finished pictures
Jeff
Jeff Louis
1977 Pinto Runabout
nectarsis
that is CLEAN  8)....are these the after pics?
PINTO LOVE
Scott Hamilton
Sweet!
Sent from my iPhone using Tapatalk Pro
jlouis707
Jeff Louis
1977 Pinto Runabout
SpaceCowboy1979
jlouis707
Hello Group -  Working on some mechanical fixes and engine compartment clean up on my 1977 Runabout.  I have only 40K original files but my Pinto was in serious need of a brake overhaul on the original brake system and leaky fuel pump.   I decided to replace the timing belt, water pump and thermostat and complete carburetor rebuild.   I de-greased over 43 years of engine dirt build up and added new belts and hoses.   I attached a few pictures f the work in progress. Close but not finished yet.
Jeff Louis
1977 Pinto Runabout
