Date: 10/31/2018 12:00 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
Date: 08/24/2018 02:50 pm
Wheels and Parts
Date: 07/06/2018 04:50 pm
Date: 10/28/2018 08:45 am
Date: 09/10/2018 10:41 pm
Date: 07/21/2017 11:49 am
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
pintos for sale
Date: 12/11/2018 04:29 pm
  • Online today: 802
  • Guests: 165
  • Total: 165
Installing door weatherstripping
Started by 442, August 21, 2019, 06:13:46 AM
442
I installed the door seals this morning using the method you advised and it worked great, thanks again for the help!
442
Thanks for the insight Bill, I will try that method with the soldering gun and use glue as well.  I do still have the original retainers, may as well use them.
Richard
JoeBob
I redid my door seals just 6 months ago. I received "T" clips with the replacement seals. My new rubber did not come with premanufactured holes for clip insert.  A member here suggested I use a soldering gun to melt holes where needed. I worked well.
   Install rubber and hold in place with tape. Bend back the rubber to make new hole adjacent to intended receipt hole in door frame.
When I removed the old seals there was some glue at the sharp turn but was dry every where else.
My seals seem to fit well yet leak a little air. I am going to remove it and add glue all around. I also found that the new clips did not hold as well as the original clips so I reused them.
    I believe you may not have clips. I would try Rockauto of Original Parts Group. No one has pinto parts but most fords of that vintage are the same.
Good luck
77 yellow Bobcat hatchback
Deuteronomy 7:9
442
I bought aftermarket door seals for my 72 hatch and am looking for advice on installing them.  It looks like the original seals were held in place by a bunch of little T shaped retainers, but not sure how they held anything unless they were imbedded in the original seals?  (Seals are missing on the car).  Do you guys just glue the seals and call it a day?
Thanks
