71-73 Pinto Parts
Date: 06/06/2019 10:47 am
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
74 pinto
Date: 09/11/2016 06:32 pm
Crane Cam
Date: 02/26/2018 07:50 am
Date: 03/07/2017 07:03 pm
Date: 06/24/2020 06:12 am
Date: 04/10/2017 07:30 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 12/13/2016 10:25 am
  • Online today: 548
  • Guests: 281
  • Total: 281
'73 Wagon tricky to fill up?
Started by bullmoose, September 12, 2005, 10:59:29 AM
renton481
Try holding the nozzle sideways.  That's what I have to do to fill my 79 wagon up at a lot of stations.  Otherwise it cuts off after a second or two.
I was thinking the filler neck might be stopped up?! I can't really see how though it's a fairly large diameter tube.
Do you think it might not be venting well? If the pump nozzle is fitting to tightly and there is no other way to vent I can see that as a problem.
My 79 wagon has the same problem from time to time.  In my experience it just seems to be the pump nozzle?
Hello  bullmoose,
On my 72 Pinto I installed a late model filler neck with the smaller hole for the un-leaded nozzle.
the 73 Pinto was not designed in mind for un-leaded fuel and the regular leaded fuel nozzles were much bigger.
The only other thing I can think of to point the nozzle down by holding up on the handle.
YOU PRETTY MUCH HAVE TO HOLD THE HANDLE ANYWAY BECAUSE IF YOU DON"T IT WILL FALL OUT.
bullmoose
That's the first thing I did, but it doesn't help.  :)  So I thought maybe others have had this problem.
Hey Bullmoose,
Try not putting the nozzel so far in the filler tube.
bullmoose
I am having issues filling up my gas tank.  I'll put the pump in and it will fill 2-3 gallons just fine but then stops.  I have to pump super slow from that point on to get the tank full.  Anyone else had this problem/or know how to alleviate it?
