Date: 03/06/2017 01:19 am
Date: 06/12/2018 08:18 pm
oldskool787
Date: 02/12/2017 12:42 pm
Date: 03/06/2019 06:40 pm
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
74 hood
Date: 07/03/2017 03:46 pm
Date: 08/08/2017 01:44 pm
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
  • Online today: 2,399
  • Guests: 1572
  • Total: 1572
Sticky ignition switch
Started by dennisofaz, July 13, 2019, 09:16:26 AM
Could be a couple issues.  Could be the switch on the column under the dash that is dirty or your cylinder is worn/dirty.  I would maybe first put some graphite or lube in the cylinder and see if that helps.  If not, maybe pull your steering wheel and drop the column and see if you can see where it is sticking at.  Everything is mechanical the key actuates a rod so that stuff might just need a good cleaning. Good luck to you.
dennisofaz
I have a 74 Runabout and the ignition switch is starting to stick sometimes.  What can be done to fix the issue?  Thanks in advance for any suggestions.
