  • Online today: 261
  • Guests: 197
  • Total: 197
Does anyone know where to buy leaf spring u bolts?
Started by russosborne, May 25, 2019, 06:28:18 AM
PBPinto
I just put these on an 8" out of a 1977 Mustang II into my Pinto wagon.
Slightly longer than stock...but perfectly bent.
$7.61 each with free shipping...
https://www.ebay.com/itm/Leaf-Spring-U-Bolt-Fine-Thread-2-Longer-1965-1966-Mustang/362565510801?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
If you buy them from the Mustangs Unlimited website they are not expensive enough for free shipping...
http://mustangsunlimited.com/Mustang/Suspension/Leaf-Springs/Leaf-Spring-Hardware/Leaf-Spring-U-Bolt-Fine-Thread-2-Longer-1965-1966-Mustang.axd
Cherry Bomb
1978 Pinto Wagon
Bought with 21,342 original miles
Currently 22,230 miles
Original: 2.3L - C3 Automatic - 6.75" Open Rear
Current: 8" 3:55 Limited Slip
Coming Soon: 302 - C4 Automatic
Caretaker: Paul B.
I want to say the last time I put lowering blocks on one of my Pinto's I got u-bolts from the local trailer parts supply store.  They were tons cheaper than having them made and they were on the shelf.
Yep.
The MII rear tubes are 2  inches. I thought they were bigger also, but I measured both a ubolt and the tube. I knew they were smaller at the ends than a normal 8inch, but not this small.
I have found a place online, but with shipping it will be about $45 for 4, with nuts and washers. Half inch diameter, the stock ones are about 7/16ths.
Have to think about that one for a bit. This is part of the "it's been a while since I have done this stuff sticker shock".
Thanks,
Are you talking about the u-bolts that go over the axle tubes? Which 8"rear? I've never heard of them being as small as 2.0".
Specifically for the 8 inch rear?
2 inch inner width, and I am not finding any that size.
Thanks,
