78 fender and hood
Date: 03/23/2021 01:07 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
$300 Pinto for sale
Date: 04/19/2017 10:24 am
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Date: 02/28/2018 09:18 am
New cam
Date: 01/23/2017 05:11 pm
Date: 08/09/2018 07:49 am
Pinto Watch
Date: 06/22/2019 07:16 pm
  • Online today: 802
  • Guests: 180
  • Total: 180
77 Runabout parking brake help needed
Started by RacingTempo, May 20, 2019, 04:49:26 PM
the parking brake set up is very common to other cars , simple to fix , first you have to make sure everything is there , sometimes someone has worked on the car and you can leave out a few parts and you have a problem with the parking brake , starting from the brake handel you will see a rod with two jamb nuts , the rod goes trough a rubber boot to the transmission tunnel , look under the car (right above the front driveshaft U-joint ) you will see the rod hooked trough a round braket and the one cable loops around it , if all is good have someone pull up on the brake handle while you look at the cable , both left and right cables should pull out the same , if one pulls out way more that brake may have missing parts , if the cable does not move much you will have to lossen the two jamb nut on the handle rod and run the nuts in , (shorten the rod , ) if that works keep turning them in untel the handle moves half way up and parking brakes are on , lock the two nuts back , your done hope this help for starters
RacingTempo
Ok folks, new owner and member here. I had the search function and didn't find these specific as, so I figured I'd ask. I just picked up this car last month and am new to the Pinto family and don't want to break anything while taking this apart, since I know parts tough(impossible)to find. My parking brake doesn't engage and I need to take the cover off of the lever to see what's going on. The cable underneath is all in tact, but the lever doesn't seem to be connected. Any advice? Pictures? Thanks in advance - Ted
Mesa, Arizona
77 Pinto Runabout. Vinyl top, sport mirrors, big back window,2.3, C3
63 C10 longbed. 350, auto, custom build ongoing
