72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Date: 12/31/2017 11:14 pm
Date: 01/23/2017 07:41 am
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Date: 01/28/2019 05:15 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
  • Online today: 600
  • Guests: 299
  • Total: 299
Cracked head
Started by 1977Bobcat, March 28, 2019, 04:32:12 PM
The Whistler
Also on a side note. If you are not too familiar with these heads you can cause a host of headaches! Take a sound clip of the engine running and post it here.
Turbo is a way of life
The Whistler
Yes engines can and will knock when and if you have a dead cylinder! You may not like this. Sorry you did not repair or replace the head. It would have been much cheaper and you would have been a lot happier.
A dead cylinder doesn't knock.
What did you take the car in for to begin with? What did the shop actually do and/or bill you for? What was the deal with the spark plug that had "mechanical damage" back in October?
1977Bobcat
I got the pinto back from the shop.  It doesn't sound great, but runs and drives. Think it has a dead cylinder because it is knocking.  The shop gave me good deal because they couldn't fix it. So now I have all these new parts on a broken engine.
I drove it home.  Washed it thoroughly, and parked it in the back yard.  It still looks nice, but I don't have the money or mechanical know how, to continue.
Yes, where is it cracked?
As some background, turbo 2.3 heads are almost universally cracked between the seats by now. They are so prone to cracking that it's usually a surprise when they haven't.
The typical course of action with those is to either run it anyway or install hard seats to stop the crack before it worsens and hits water.
The Whistler
Repair the head or replace it
Where is the crack?
Any kind of advise like this is "Do At Your Own Risk" but I have a crack right through the valve seat on my Turbo motor. Hearing almost all these heads have cracks I just went ahead and used it. I don't drive much (maybe 3,000 miles in 8 years) but so far..., so good.
1977Bobcat
I was just informed that my bobcat has a cylinder head crack.  The mechanic says it is a hairline crack, so I need to decide to replace it or use it until it fails.
I was trying to get my Bobcat ready for the Stampede, so had the head rebuilt, new radiator, new distributor, new timing belt, new plugs and wires, new carburetor.
And now this.............
Car has been already been at the shop for a month
