Date: 03/30/2021 12:29 pm
Date: 07/17/2018 09:49 pm
Date: 03/21/2017 07:47 pm
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
ford pinto door panels
Date: 03/20/2022 07:51 pm
Date: 07/08/2017 08:25 pm
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
Date: 01/23/2023 02:22 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
  • Online today: 531
  • Guests: 486
  • Total: 486
351w vs 302 ?
Started by grgic, September 09, 2005, 05:04:07 PM
All Great points pintoguy76.......... ;D
The 351 is alot heavier. It will be harder to fit, hurt traction (as mentioned before) because #1 the extra torque it will make. #2 It adds MORE weight to the front and (think about this a little) pushes the front down and  causes it to "lift" a little on the back, hurting traction even more. You're also going to need subframe. You'd be better off doing what im going to do. a 2.3L EFI Turbo swap. I know of somone who ran a 12.2 with a 2.3 that was almost stock other than a larger turbo and larger injectors (not just a huge turbo upgrade either) and yet another guy with a twin turbo efi 351w pinto only makes a 12.7 and is bound to get much worse gas milage  than the 2.3 turbo. Yes it looks nice and sounds mean and stuff, but thats got to be a horrible traction problem. Just my two cents here!
RLK
Hope your ready to do frame. If you want to go crazy do a 347 Stroker
79pinto302
for a mustang II oil pan i called auto zone and they special ordered it it cost around 70$$
flipped mustang shorties will work on a 351w into an early Pinto
pinto_351
i don't think that headers for a 351w will fit in an early chassis. not sure what the difference is but the hooker catalog list 74-80.  A set of mustang ii 302 manifolds may work though. or you can run a set of 5.0 mustang headers if you flip them side to side and run them dumping forward.  also with the 302 you have to find a mustang ii oil pan and those can be tricky to find cheap.  just my two cents.
brad #2
grgic
Thanks Bob
I dint think I want to get that expensive or involved with this project.
I still wish i could find a decent used 2.0
Joe
Great answer Bob. A "one up for you"
Bipper
Well since no one has responded, here's my 2 cents.  As far as getting the engine and trans in the car there are not really any different fitment issues between the 302 and 351w.  They share the same bellhousing bolt pattern , motor mount locations and overall engine lenght.  But since the engine is wider the exhaust is going to be the main difference.  I don't know if stock exhoust mainfolds will fit.  The 351 pinto's I have seen have all had the hooker headers.  They are different than the 302 headers.  On the 351, 2 tubes go down along side the engine and the back 2 exit through a hole you have to cut in the fender well, then snake around back under the car and join up with the other 2 tubes at the collector.  Of course the only place you will find these headers is e-bay and they ain't going to be cheap.  But maybe maifolds will fit, I've just never seen them on a 351.  The other thing to consider is you will have traction issues, at least on the street with the torque of a 351.
Bob
71 Sedan, stock
72 Pangra
73 Runabout, 2L turbo propane
grgic
This is most likely a stupid question however, after the sudden demise of the  2.0 in my 72 pinto I have decided to go with a V8 (mostly due to unavailability of parts or just something I always wanted to do)
I wanted to go with a 302 c4 combo which is going to be a big enough pain to put in the pinto but I have just come across a 351w in a whole running car for an unbelievable price.  How much more trouble will i have putting that into my 72 than I would have with the 302. I know the 351 is a bit higher and wider but not sure how much.
I have no problem going with a hood scoop but don't want to ruin my car putting in the engine.
any thoughts would be appreciated.
Joe
