Date: 01/23/2017 07:41 am
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 08/22/2017 09:21 pm
Date: 08/26/2018 06:35 pm
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
Date: 10/28/2018 08:45 am
Date: 02/04/2018 08:26 am
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
  • Online today: 535
  • Guests: 506
  • Total: 506
Leaf Springs, !973 Pinto Wagon
Started by PonyRider62, February 14, 2019, 01:34:15 PM
PonyRider62
Not Sure, But I Think He Torched Both Coil And Leaf Springs!
She Rides Like A Tank!
Save The Ponies!
Allen D. Hoffmann
Quote from: Wittsend on February 16, 2019, 08:11:14 PM
Were the rear leaf springs re-arced?  Typically people just use lowering blocks that can be removed and the stock height restored. BTW, the wagons have a longer leaf spring than the sedans. They also take a slightly longer shock that is rather hard to find and can be expensive.
Lowering blocks can worsen spring wind up under acceleration. I wasn't about to restore the car to stock
PonyRider62
Thanks For The Feed Back!
I'll Keep Looking!
Save The Ponies!
Suspension wise a 1973 wagon (yea, I have one too) is probably the worse Pinto to have. The wagons have the longer springs and rear shocks, - and all the '73 Pintos have the one year only steering rack, one year only front spindle (just found that out recently) and the difficult to find and expensive '71-'73 rotors. So much for being a "common, economy" car!
My "how to build a Pro Stock" says the 73 spindles were stronger than the 71 / 72s.
JoeBob
Denver no longer has a spring shop for environmental reasons. We don't have a chrome shop anymore for the same reason.
77 yellow Bobcat hatchback
Deuteronomy 7:9
Allen D. Hoffmann
If your on the left coast get a hold of https://bettsspring.com/   they can make them stock or custom. Front springs get the Moog catalogue it's just diameter and spring rate. Cut to fit
I'm building a 72 sedan into a go fast car.
Called Standens Axle in Calgary & asked if they could make a new set of springs for me.
Yes, they can.
So any good spring place near you should be able to do the same......
PonyRider62
Anyone Know The Part Number For Leaf Springs And Front Coil Springs For A 73 Wagon?
Idiot Who Had This Car Lowered It.    I Need To Get It Off The Ground!
Save The Ponies!
