Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
Rear brake shoes
Date: 01/23/2017 05:01 pm
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
Date: 08/01/2018 01:27 pm
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Automatic transmission
Date: 02/13/2021 02:52 pm
Date: 11/14/2019 04:02 am
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
  • Online today: 563
  • Guests: 362
  • Total: 362
5 Speed Transmission
Started by PonyRider62, February 14, 2019, 01:24:50 PM
PonyRider62
Thanks Guys!
I'll Have To Wait Till Summer To Do Anything With The Motor And Trans..................So Broke
Save The Ponies!
The Whistler
On my current set I have 3.55 in the rear. I had 14'' all around until I got a set of 15'' wheels. I never had a problem out  of bog on acceleration even when I ran a stock ECU. With the turbo I always had over kill of power and torque. My Pinto is a 72 hatch. I tried Many different rear ratio's I found the stock ratio Ford used on the Thunderbird worked best for a street app. Also there are different T5s not all are the same. The more torque and hp you have the less dependent you are on gear. But all said and done the T9 is the easiest to install  almost bolt on lol but you would still need to change the rear gear ratio. You get the right gear ant tire combo that car should be a blast to drive around town and a dream on the interstate. Just like any modern car and you may see a noticeable change in fuel economy.
Turbo is a way of life
I'll add a +1 for the 3.40 gears assuming tire roughly the stock size of 13". When I went with a Turbo 2.3 I got a 3.00 8" rear end. Ironically even with 215-60-14" tires it wasn't so much that the car bogged (on acceleration under boost), in fact I liked the long-er pulls under boost. It was just that at every legally posted speed limit the 5 speed gears were either too low or the adjacent gear too high. Thus everyday driving was rather unpleasant. With the 3.40 and 175-70-13 tires the car at 65 MPH is about 2,600 RPM in 5th gear. At other (lower) legal posted speeds the RPMs are much more appropriate too.
I know we are talking rear and trans ratios here but if you have rather tall tires 3.55 might be applicable. Remember that it is the tire size, not necessarily the wheel size that matters. You can have a 185-80-13 tire and it will have a similar height to a 225 40-17 tire. The tire size it every bit as much a factor as the gear ratios.  This can be helpful.   https://tiresize.com/calculator/  There are many gear ratio calculators out there too. Just do a search. Having the wrong combination of tires, rear gears, transmission gears does not make a 5 speed trans "better" to have.
The Whistler
In order to bolt a 2.3 bell housing to a 2.0 block you will need a set of step dowels made or buy a set from Paul on Turboford. You will need them for proper Bell alignment if you use a T5 trans! Also I would recommend changing your rear diff gear to a min. of 3.40 final drive. The T5 uses a 10 spline input so you would have to use a small diameter 10 spline clutch disc.
PonyRider62
Thanks For The Input Guys!
I Just Got This Car For Christmas.....
Don't Know Much About It, Engine Maybe Modified But Not Sure, Has Headers And Runs Ok.
Been 30-35 Years Since I Had A Pinto.... Trying To Remember What I Knew About Them
Save The Ponies!
LongTimeFordMan
Wikilinks indicates that the t9 was also usedin the 1.6 and 2.0 l capri????
https://en.m.wikipedia.org/wiki/Ford_Type_9_transmission
But i think the article was wrong and the 2.0 only had a 4 speed and the later capri had a 2.3
And there were several input shaft configurations
https://www.bearingkits.co.uk/How-to-tell-what-Ford-Type-9-gearbox-you-have/B19.htm
Also is the total length and shifter location the same as the 4 speed type e
LongTimeFordMan
Also.. have you done any mods to the engine.. are you sure the 2.0 will have the torque to pull the taller ratio in 5th gear..
How many revs is your engine turning at highway speed and do you have a high rev cam installed?
The stock 2.0 cam was retarded to raise the power curve. The specs rate the max torque at 3000 rpm and max power at 5800
The result is that the power curve usually starts at about 3000 to 3100 about 60 mph in 4th gear
But the stock weber 2 bbl usually wont feed the engine much over 4500 rpm so the power curve is only about 1500 rpm
The result is that power curve comes in too high to pull 4 th gear below about 60 mph so except for  flat land cruising the higher ratio of the 5 speed probably wont be useful
I had a 72 wagon and had to downshift for hills
I now have a 73 with 14" wheels, installed an adjustable cam pulley and advanced the cam about 6 degrees. That moved the power curve down about 600 rpm so the cam srts working about 2400.
A carb upgrade allows for 6000 rpm but I shift around 5500
With 14 inch tires 3.40 rear end i now cruise easily at 3000 rpm at 70 mph and can loaf around town at 40 mph at 1800 rpm in 4th gear
I have considered a 5 speed but am not sure if the engine could pull 70 mph at 2600
Switching to 14 inch tires and rims is a much cheeper and easier solution since it provides the equivalent to a 10 per cent over drive. And the cam advance and a ford 2bbl will cure the carb and torque curve problem
Quote from: Wittsend on March 02, 2019, 11:45:18 AM
The T-5 is an option. I believe (someone correct me if I'm wrong) the 2.3 bellhousing will bolt to the 2.0 block as it has secondary mounting holes to do so.
It's the other way around; a 2.3 block has both 2.0 and 2.3 bellhousing patterns. Only the lower four bolt holes of a 2.3 T5 bellhousing will align on a 2.0 block though.
The T-5 is an option. I believe (someone correct me if I'm wrong) the 2.3 bellhousing will bolt to the 2.0 block as it has secondary mounting holes to do so. You would need a pre-87 bellhousing. I used the 86 bellcrank bellhousing on my 2.3/T-5 swap. The other questions then become does the pilot bearing fit the input shaft, the splines fit the clutch disc and the starter bolt in without issues???
Note that some have used the T-5 but the consensus is varied. Some find it OK while others say the slightest incline (or head wind) force you out of 5th gear.
And they're rare in the U.S. because they only came in the '83-89 Merkur XR4Ti, of which the youngest is now 30 years old. Their 5-speed is referred to as the T9. They are still out there, but you might have to shop around. AFAIK it's a drop-in replacement for the Pinto 4-speed. Since the Merk made 2x the power and 3x the torque, it should last practically forever behind a stock 2.0.
LongTimeFordMan
I think a merkur 5 speed..
Its a FoG 4 speed with an additional gearset  bolted onto the rear like an overdrive..
Pretty common in europe but rare here..
PonyRider62
Hi All!  I Have A 1973 Pinto Wagon With A 2.0 Engine And A 4 Speed Transmission
What 5 Speed Transmission Would Bolt In?
Save The Ponies!
