Looking for front seats
Date: 08/10/2021 09:54 pm
SVO SWAP
Date: 03/15/2018 03:12 am
Date: 05/22/2018 01:54 pm
Date: 10/24/2018 07:41 am
Date: 11/11/2019 04:49 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
Date: 03/18/2020 01:30 am
Date: 12/10/2017 01:14 pm
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
  • Online today: 1,612
  • Guests: 1638
  • Total: 1638
Starter issue on 1972 Runabout
Started by Wrench Monkey, February 08, 2019, 11:19:16 AM
Wrench Monkey
The car took some convincing to start at first, but generally would start after a few seconds. The battery is only 4 months old an sits on a trickle charger when it's not in the car. I did leave the battery disconnected overnight, but haven't checked on the car today. I will keep this thread updated with any progress, and I'm hoping that the starter motor isn't going bad.
If the car started OK when you picked it up, either the battery is weak (and was charged just prior to you getting there), or something is draining the battery while it sat. Try recharging the battery (for a decent period of time) and see if that helps. If it does then disconnect the battery overnight. If it starts fine the next day there is likely something draining the battery. If it doesn't start the battery is likely bad. Doors not shut can leave a dome light on that can kill the battery.
As for the brakes look under the car around the backing plates or the calipers and see if brake fluid is weeping anywhere. Also look under the dash, there is a rod that goes from the pedal to the master cylinder. See if there is any brake fluid leaking there.  On a 47 year old car you do not know the history of it isn't a bad idea to rebuild the brakes.
I'm not familiar with specifically the shifter and 1st gear issues. But I do know there is a problem with the manual trans and a plastic piece that affects shifting (I recall it more affected reverse???). So, that might be the problem. Hopefully someone else can provide a better answer. As for the smoking when forcing it into 1st gear (were you moving or stationary?) if the car was moving when going into 1st gear it likely revved very high. IF that was the case it might be a clogged PCV system or worn valve seals, or worn piston rings. Sometimes if a car has sat for a LONG time the rings can gum up and SOMETIMES driving the car with fresh oil can help them to free up.  But, again you are dealing with a 47 year old car so don't expect too much.
The more you provide about the history of the car, and when applicable, provide pictures the more people will be able to help.
Wrench Monkey
Hi everyone!
I drove my pinto home yesterday from the seller's home and the drive back was incredibly scary. The car wouldn't want to go into first gear and if you forced it in then it would smoke heavily. The rest of the gears were fine and the general drive back was smooth aside from the first gear issue and the brakes almost failing. Now that the car has sat overnight, it does not start. It sounds like the starter motor grinds when you turn the key, but I do not know the actual source of the issue so I am coming here for help.
Many thanks,
Wrench Monkey
