77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
Date: 07/08/2022 11:51 pm
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
Esslinger 2.0 intake
Date: 03/06/2017 11:58 am
Date: 08/30/2021 03:20 pm
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
KYB shocks
Date: 02/08/2017 07:09 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
76 drivers fender
Date: 07/20/2018 08:24 pm
  • Online today: 261
  • Guests: 188
  • Total: 188
5.0 oil pan
Started by WF250G, February 03, 2019, 09:52:32 PM
WF250G
Thanks for the information. Just wanted to ask did the oil pan clear the cross members of the front end? Or did you have to move the motor mounts to get the engine to fit? Thankd
https://www.milodon.com/oil-pans/ford-oil-pans.php
Keep in mind you are building a go fast car. A 5 qt pan without oil control & you have very little oil left in the pan...
I use the above pan on all my builds.
I tried this on a newer block. Fits perfect. Only difference was the dip stick on that block was in the side of the block. Just tap it & a plug, then use a timing chain cover with the dip stick & you are good to go.
Also, if you use a CVF Racing short water pump (and the Pulleys meant for this) you get another 1 1/2" of more clearance.
https://www.cvfracing.com/search/searchresults/?search_query=ford+short+water+pump
WF250G
I have a 1980 Pinto that I want to put a 5.0 with automatic transmission, I just started to do this and see the oil pan will not clear the steering and cross member on the frame. Can someone give me information on what I should do, get a oil pan with the sump in the front or something else. Thanks
