Date: 04/06/2017 12:13 am
Seeking parts
Date: 10/18/2020 10:35 am
Date: 12/31/2017 11:14 pm
Date: 08/30/2021 03:20 pm
Date: 02/05/2017 09:45 am
Date: 02/04/2018 08:26 am
Date: 02/18/2017 04:44 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
Date: 07/13/2018 02:21 pm
  • Online today: 261
  • Guests: 196
  • Total: 196
Strut rods-what are they for on the Pinto?
Started by russosborne, February 02, 2019, 12:21:05 AM
On my Datsun 510 the strut rods are fixed from the factory. But my friend who gave it to me added aftermarket adjustable rods. The 510 is a McPherson strut car and without special upper pieces everything is "fixed" except for toe. But if there are other options at the upper A-arm then I can't see an advantage on a Pinto. It is probably not good on the lower inner A-arm bushing either.
In the "do at your own risk" category if you desired more caster one could cut the inner rubber bushing and then add extra washers to the outer rubber bushing. But I think there is a rather small limit to how much you can remove and still have motion in the joint.  For sure this will throw toe off and it will need to be adjusted. On my Sunbeam Tiger the caster is adjustable at the A-arm BUT..., the crossmember is removable and wedges are used between it and the frame rail to also set caster.
On the Pintos I have seen (71-73 & 79), the strut rods are a fixed length and not intentionally adjustable.  The Pinto's use the upper control arm adjustable inner attachment for alignment (castor and camber) adjustments.
Are they used for alignment like on a
Mustang?
Something I never thought about until now. :-[
Thanks
