2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Date: 04/07/2021 06:12 pm
Wheels and Parts
Date: 07/06/2018 04:50 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
Date: 01/19/2020 09:06 am
convert to stick
Date: 05/19/2018 09:26 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
74 hood
Date: 07/03/2017 03:46 pm
  • Online today: 261
  • Guests: 202
  • Total: 202
4.6 or 5.0?
Started by Jlb2370, December 30, 2018, 10:28:36 AM
WF250G
I have a 1980 Pinto and found a 5.0 HO with automatic transmission will this fit or do I need another oil pan with the sump in the front. Thanks for any help.
LongTimeFordMan
What about a 289 or turbocoupe.. wouldnt the hp be similar with the turbocoupe and a little work with a lot less weight..
Jlb2370
I appreciate the input. I had no idea the 4.6 was so much wider than the 302.
Yeah, a 4.6 would require major surgery to your car. Losing the fender wells and reinforcing the subframe at a minimum.
I had one given to me back when I owned a different 79 with the intention of doing that swap, but unless you are a very good welder/fabricator or know one who will also work cheap it probably isn't worth it.
If you happen to have those skills, have fun. It could be an awesome swap. Although most here would say you have ruined the car since this falls into the "Can't reverse the mod" so many feel is important.  It has been done with a Mustang II a few times, but not exactly the same engine compartment as our Pintos.
A 5.0 (302) is a narrow V-8 that is hard enough to fit in a Pinto. A 4.6 is a W-I-D-E V-8 and virtually impossible to fit.
Jlb2370
I'm wanting to put a V8 in a 74 Pinto I bought for parts. The car is in better shape than I first thought and now I want to do something with it. So 4.6 or 5.0?
