Date: 06/07/2021 08:14 pm
Date: 12/09/2016 08:34 am
Date: 03/29/2019 07:20 am
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
Date: 05/28/2017 03:20 pm
Date: 02/18/2017 05:55 pm
Date: 12/09/2018 06:59 am
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
  • Online today: 261
  • Guests: 232
  • Total: 232
Hub centric or lug centric ?
Started by Reeves1, December 24, 2018, 06:06:09 AM
I always thought/assumed that taper-seat lugs meant lug-centric and washer seats were hub-centric. I think wheels run truer when they align on the hub regardless of lug type, therefore...
I'd think any stamped steel wheel regardless of its "centric" is going lack some accuracy.  On the other hand I'd also think any alloy aftermarket (or factory) wheel would be hub and lug centric at the same time otherwise thay wouldhave some pretty sloppy machining practices.
On the Centerlines I'd think anything that looks like steel (but as you have found isn't) it probably just rust transfer from a previous installment of the stell hub.
Note: not steel inserts. Tried a magnet on them yesterday.
Sent an e mail to Center Line as well.....
From what I have seen, the Ford steel wheels are hub centric.  Have not worked with Ford aluminum wheels.  The aftermarket aluminum wheels that I have used were just lug centric (no experience with Centerline).  Ideally, both the lugs and hubs should put the wheels in the same location.
Note the 71-73 Pinto hubs are smaller than the 74-80 hubs.  So the 71-73 Ford steel hub centric wheels will not fit over the 74-80 hub.
1972 Pinto fronts.
Googled it & no answer.
Reason I ask is both my old & new front Centerline wheels the hub has a gap.
There is a steel insert in both.
You can (sort of) see the insert in the right wheel ?
