1978 fuel sendng unit
Date: 05/27/2020 09:54 am
convert to stick
Date: 05/19/2018 09:26 pm
1975 Ford Pinto
Date: 01/13/2020 11:02 am
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Date: 07/17/2018 09:49 pm
Date: 01/20/2018 07:51 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Date: 12/09/2018 06:59 am
79-80 full glass hatch
Date: 01/04/2017 04:04 am
  • Online today: 261
  • Guests: 223
  • Total: 223
Spark plugs for 2.0 engines..
Started by LongTimeFordMan, November 20, 2018, 11:42:16 PM
cossiepinto
I have several dozen spark plugs for the 2.0 Pinto left over from a Trans Am Pinto I owned back in the day.  The buyer didn't want them, so I wound up keeping them all these years.  I don't remember all the heat ranges, but they are both Autolite and Champion plugs, all in the original packaging.  There are a few (maybe a dozen) that were run in the car, but the rest are brand new.
I can check them out for anyone who's interested.  Whoever that might be can contact me for more details.  I remember I laid them all out, inventoried, and took pics of them once.  I bet I still have the pics.  I'm pretty sure I never sold any individually, so the pics/inventory should still be accurate.
Btw, the Trans Am Pinto was raced in vintage by the guy I sold it to, and now is back at Galpin Ford in Sepulveda, CA, in the Galpin museum.
Regards,
Cossiepinto
LongTimeFordMan
Hi all. Glad to seethe forum is back up.. in the downtime I found the facebook site and came across a post asking for spark plugs for  uilt 2.0 engines..  the factory plugs are autolite 42 or motorcraft 420.  And for higher compression, higher revs colder plugs like BF 32 were  used in days past. But alas all the info I have found indicates that the 32 range plugs are no longer made
Most parts stores substitute 42 range plugs which are "supposed" to be replacements but are too hot.  After a lot of research I found that autolite makes a plug   umbered 124 which is equivalent to a BF22 cold plug.  .it isnt a projected tip but runs a lot better than the 42 range.  My car is stock with 8.1 compression and with the 124 plugs gets about 500 rpm more than with the 42 range.
The 42 range plugs run white, the 124s run grey, and ive run them 5000 miles around town in dallas winter..but for the price you can afford to replace  .them once a month if they foul....autozone stocks the 124 for $.75 each.  They are not resistors and prolly need resistor wires..
Just some info
