Date: 10/02/2017 02:16 pm
Date: 08/13/2021 10:39 am
Hatch needed
Date: 09/10/2017 09:16 pm
Bell housing
Date: 08/23/2017 05:41 am
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
Date: 12/31/2017 09:03 pm
Date: 02/10/2017 09:30 am
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
  • Online today: 261
  • Guests: 191
  • Total: 191
4wheel disk brake booster
Started by halfhorse, November 02, 2018, 12:37:47 AM
If you are converting TO power brakes you have to install the parts behind the dash , done this before , there is a plate behind the firewall you have to change , and install the plate that holds the booster , you have to remove the steering column to remove the brace to the fire wall to the dash , it's all tied together, takes about two hours for the first timer
halfhorse
 Got the studs out.Auto zone had a better extractor.15$ get one! When I get finished I'll post the process if anyone is interested
halfhorse
 I've added turbo Tbird  disk brakes to my 77  turbo pinto.I want to install a 7" brake booster but the original  non power brake master cylinder  mount studs are in the way. I've tried a stud remover but they won't budge Anybody removed them? I don't want to just cut them off.Thanks
