76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Date: 05/13/2021 05:33 pm
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
Date: 11/08/2019 10:01 am
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
V8 rear end
Date: 04/12/2018 10:57 am
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
  • Online today: 261
  • Guests: 207
  • Total: 207
Has anyone here used a small block C6 trans, and what did you do to make it fit?
Started by russosborne, October 31, 2018, 11:49:09 PM
Thanks.
I was using the C6 as that is what I have, came with the engine.
But I am going for broke (literally) and putting a manual in.
Already have a steel MII sized bellhousing on order.
A good built C4 will work , even if the 351 pulls over500 HP it will live , and much cheaper in the long run , one you can use the stock shifter if you like , it fits the tunnel , it's also the same gear ratio as the heavy c6 , standard is nice also , T5 are kind of
cheep but almost the same money , well at least where I live ,
Update.
I am going to go manual, it's what I really want. So what if it takes me another month or two.
Thanks,
I've been doing lots of searching here and the internet in general, but other than hearing the "it won't work without lots of work" type comments I haven't found anything that has been done to make one fit.
351W engine.
If I have to drastically modify the tunnel or firewall so be it, but I am hoping to get some direction before I start. The car is already drastically modified so a little more won't hurt anything but my wallet.  ::)
Thanks,
