Date: 08/02/2019 04:18 pm
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Date: 09/21/2018 11:35 am
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
77 pinto
Date: 08/22/2017 06:31 pm
71-73 Hood
Date: 12/07/2018 06:22 pm
Wagon rear quarters
Date: 06/17/2020 03:32 pm
  • Online today: 261
  • Guests: 198
  • Total: 198
Master cylinder for a 4 wheel disk system?
Started by russosborne, October 14, 2018, 01:35:41 AM
Thanks.
I'm finding that a lot of what I thought I knew doesn't necessarily apply to Pintos, or I didn't know as much as I thought I did. Like with this, I can go to a Mustang site I am on and find out exactly what model master to get, but that might not be the right one for a Pinto.
Just hoping to do this without any really expensive mistakes.
I actually never thought I would have the money to do all this stuff so I am a bit under prepared.
Yes you will have to change the mater cylinder,  rear drum brake cylinders have a valve to keep a slight pressure on the rear wheel cylinders , if you were to use it on rear disk brake set ups it would have dragging rear brakes , also the duel disk brake cylinders have more fluid capacity in the rear part of the cylinder , note small area when you fill a stock pinto cylinder , also they are different bore sizes, kind of hit and miss on none power brake cars , try a Ford Fusion cylinder that has duel disk brakes ,  close to the weigh of the car , but you still  might need a adjustable proportioning valve to fine tune it , only a drive test will find out for sure , good luck
If anyone has done this please let me know what master cylinder you ended up using.
I will be using an adjustable proportioning valve, but I am pretty sure I need to change the master cylinder regardless.
Thanks,
