Date: 01/12/2019 10:19 am
Oddsnends
Date: 12/20/2016 10:52 am
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
Sunroof shade
Date: 06/19/2019 01:33 pm
Date: 01/28/2021 03:49 pm
77-78 front grill
Date: 04/07/2017 12:35 am
Date: 05/19/2018 04:56 pm
  • Online today: 261
  • Guests: 184
  • Total: 184
Sanity check. Can I remove the front suspension/brakes (each side) whole?
Started by russosborne, September 10, 2018, 04:53:45 AM
Quick update.
I pulled both sides off of my 79 today.
One side came off whole, the other  side I could not break the control arm cross shaft nuts loose, so I had to separate the upper control arm from the spindle so I could move the arm up enough to get an impact wrench socket on it.
Otherwise it wasn't bad.
thanks,
Thanks.
I had forgotten about the springs, but yeah, I'll get a compressor to do those.
pintoman2.0
russosborn, I have parted many Pintos and Mustang II in my time and I always pull each side as a whole. I bet I could find at least 4 pairs like that in my shed now. Just be careful with those springs!! You might want to take them out with a compressor first.
P
Russ,
It sounds like a sane question to me.  Unfortunately, I don't know the answer... but I bet someone here will!
Dwayne :)
Dwayne, I know, what sanity? :P
Plan is to take the control arms, spindles, and brakes off the 79 and put them on the 74 as is to help make the 74 a roller.
So in a nutshell, can I do this by unbolting the control arms from the car (along with the brake lines, etc) and steering and just move the whole assembly to the 74, or will I need to take it apart more?
Thanks,
