Date: 02/16/2019 10:46 am
Date: 09/03/2018 08:58 am
Date: 07/08/2017 08:25 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 01/20/2018 07:51 pm
Date: 12/09/2018 11:35 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
Date: 07/20/2017 01:23 am
  • Online today: 261
  • Guests: 255
  • Total: 255
Disk brakes-single piston or dual?
Started by russosborne, September 10, 2018, 04:37:25 AM
I will be using the Speedway kit to put the larger 11 inch rotors on my 79. This also converts to the 5 lug pattern that I want.
https://www.speedwaymotors.com/Mustang-II-Complete-11-Inch-Brake-Kit-Ford-5-x-4-1-2-Bolt-Pattern,2008.html
Turns out it comes with single piston calipers for late 70's to early 80's GMs like the Grand Prix, etc.
Been doing some searching and have found dual piston calipers available for those cars. Might even be more, but that is what I have found so far.
So I am wondering if it is worth the extra $100 or so (obviously depending on which I get) to go with the dual pistons?
I will also be looking into getting better pads.
I won't be changing this stuff until after the car is on the road, so I may find that I don't need to make any changes, but might as well find out what is what now.  :o My ultimate goal is to put a 351C into this car, at that point this stuff will become more important.  ;D
Thanks,
