SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
New cam
Date: 01/23/2017 05:11 pm
1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
Date: 02/21/2022 11:11 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
Date: 12/10/2016 04:11 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
Date: 02/26/2017 03:22 pm
  • Online today: 261
  • Guests: 241
  • Total: 241
Side draft intake
Started by stonhed18, August 31, 2018, 04:54:28 PM
LongTimeFordMan
Here are some pix of the manifold i built and the gasket altbough the gasket doesnt have the hole for the water port cut out yet..  the red line points to the water port. Also a detail of how I c9nnecter the water outlet to the heater. Note the tee with a connection allowing a mechanical temp sensor...
stonhed18
Quote from: LongTimeFordMan on September 09, 2018, 09:05:41 AM
Have you had much experience with webbers?  Ive heard they are difficult to tune.. thats why i went with SU HIF s  only one needle per carburetor  and you can custom taper it with a hand drill and some 400 grit emory paper..
Also have you used a small wrench to tap out a gasket?
No this is the first I've used any side draft. They seem to be working well.
LongTimeFordMan
stonhed18
stonhed18
Quote from: LongTimeFordMan on September 08, 2018, 10:47:06 AM
When I built my manifold I just drilled the mounting plate and tapped it to accommodate a 3/8"  rass pipe fitting so I could maintain the original heater water outlet. I tapped out a custom gasket from 1/16" grey Felpro gasket material and sealed it with black silicon.. no leaks so far..
I'll try the custom gasket. The fitting is an issue. The runners on the intake angle back and upward interfering with alignment of the port. Thanks for the advice!
LongTimeFordMan
stonhed18
Using a duel side draft intake that blocks off the water jacket from the head. Getting some leakage. Has anyone had the same issue and solved it?
