Date: 07/08/2017 08:53 pm
Date: 11/05/2016 09:03 pm
Date: 04/04/2020 09:38 am
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
Esslinger 2.0 intake
Date: 03/06/2017 11:58 am
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
sport steering wheeel
Date: 10/01/2020 10:58 pm
  • Online today: 261
  • Guests: 247
  • Total: 247
New to me 1980 Pinto
Started by Creedmoor, August 06, 2018, 04:56:59 PM
JonzWagon
Welcome to you and your Pinto.  Just put a Remanufactured carb on my 2.3 engine (Holly 5200) got one for  Calif. smog car with automatic trans thru Auto Zone for $167.00 plus a core charge.  Came complete with gasket and choke. Took an hour and a half to replace with minimum adjusting.  Runs great. Beat the Heck out of trying to rebuild old one myself.  Also have 185/70 R13 tires on factory slot mags.  No rubbing or problems....good ride.   Enjoy your Pinto
Creedmoor
Thanks for the replies. Did some more research and it turns out that 175 70/R13's are nearly identical with the stock tires my Pony came with from the factory. Would have liked to go a little wider but got a smokin deal on a set of Hancook Optimas - $44 a tire for a 70K mile quality brand tire!
No joy in the parts for sale section or anywhere else on an outer timing cover.
Going to attempt (again) adding a couple pics. One of the carb and one of the car. Can anyone tell me what part is missing in the carb pic?  Pretty sure it's a diaphragm of some sort.
Why can't I post pics?  File size is within limits. Do I have to have a certain number of posts first?  Arghus!
PBPinto
I have 185/70R13 tires on my 78 wagon and they look great in my opinion.
Cherry Bomb
1978 Pinto Wagon
Bought with 21,342 original miles
Currently 22,230 miles
Original: 2.3L - C3 Automatic - 6.75" Open Rear
Current: 8" 3:55 Limited Slip
Coming Soon: 302 - C4 Automatic
Caretaker: Paul B.
rowdyrunabout
yes- those tires will work, but I believe 185/80 is more like stock. That's what I have on both of mine.
I don't know if the ranger timing cover will work. I would continue to look for the pinto cover. They are out there. I think you can post a want ad on here. Maybe one for sale on this site.
I would get a replacement carb. I would look up 80 pinto and order the carb it calls for. Then take off the EGR/ smog stuff. plug the manifold and make or buy a cover where the egr goes to the intake.
Creedmoor
60 views and still ... crickets.
Creedmoor
Hi guys,
Tried to post an intro in the welcome section but it doesn't seem to be there. Hope this post goes through.
Just picked up a nice little 1980 sedan and have three basic questions to get things squared away.
Tires. Need new ones. Will 175-70/R13's fit in there without issue?  Currently has ancient weather checked 80's.
Need an outer timing cover so I can time it properly. All I can find online are ones for a 2.3 Ranger. Will those fit?  Otherwise I'll have to cobble together some sort of pointer deal.
Carb. The one on there works. Sort of. Previous owner did a half assed de-smog job and there are definitely parts missing. Any simple bolt on replacements?  Maybe a Weber 32-36?
Appreciate any guidance. Thanks.
