Wanted hood hinges
Date: 02/17/2020 05:30 pm
Date: 09/15/2019 12:28 pm
Date: 05/28/2017 03:20 pm
Date: 06/28/2019 09:14 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Date: 08/09/2018 07:49 am
Date: 10/24/2018 07:41 am
Wanted hood hinges
79-80 full glass hatch
Date: 01/04/2017 04:04 am
  • Online today: 577
  • Guests: 461
  • Total: 461
73 V8 front end questions
Started by MightExplode, July 07, 2018, 05:03:50 PM
Mustang ll springs work. However they need to be cut down.
I'd have to look up what ones I used & how much.....depends on engine weight.
MightExplode
When I did some looking from what I gathered the mustang 2 would work if it was a 74 and up
Quote from: MightExplode on July 07, 2018, 05:03:50 PM
... I have looked through here and it seems like 71-73 are nightmares. Thanks
The 71-73 are the older design.  Thereafter the Pinto and Mustang II shared similar. I believe the springs are similar to all years and the Mustang II V-8 (or V-6) springs might work. Hopefully someone will confirm.
The rotors for the 71-73 are expensive (and not as good I've heard) as the later cars.  I believe there is a mix/match with 74-up rotors and GM Metric calipers to the older cars. To confound things even more the '73 Pinto's had a one year only steering rack!
Having done a '73 Turbo Swap I think I would have now bought a 74-75 car and just done the bumper body swap to make it look 71-73.
MightExplode
Hello everyone I just joined here and had some quick questions on 73 suspension parts that will be used on a V8 swapped car. The car is from Illinois it was my father's first car and the car sat for about 15 years and I'm looking at updating the front end one coil spring is broke and the suspension is soft with the V8 in there. Any help is greatly appreciated I have looked through here and it seems like 71-73 are nightmares. Thanks
