Many Parts Listed Below
Date: 04/20/2018 11:15 am
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
KYB shocks
Date: 02/08/2017 07:09 pm
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
Date: 11/08/2019 10:01 am
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
Front grill for '72
Date: 03/02/2022 12:09 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
  • Online today: 1,137
  • Guests: 763
  • Total: 763
New Carb
Started by danidanko, June 08, 2018, 05:44:59 PM
nnn0wqk
Your number 1 goes down to the fuel pump. Should be a steel line between carb and pump with hoses on each end with filter screwing into carb.
Your number 2 I believe is the distributor advance line. I am not aware of a decel port used on 74 2.3l engine
I believe your number 3 is the line going over to the EGR system amplifier.
The choke water lines one connects to the steel line running along side the valve cover. The other to the fitting below carb in the intake manifold end.
The electric choke connects to a lead coming off the alternator. It is actually an AC voltage if I remember correctly. Comes off a stator tap.
Hopefully the pictures will help you out. These are off a 74 2.3l California emissions engine. Calibration number is C411R1
danidanko
Hello, please see attached file, I got a 74 pinto and the carb is in pieces and I don't know where what goes when I put in a new carb, please help
In the picture have numbers and arrows, my questions are:
1) fuel inlet
2) decel port - what does it do where do I connect it to?
3) what is this inlet what does it do?
4 & 5)  what components do these coolant lines connect to?
6) where do I connect this (choke heater?, just 12v and returns via engine ground?)
