1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
Date: 06/07/2018 01:45 am
74 pinto
Date: 09/11/2016 06:32 pm
Date: 05/28/2017 03:20 pm
Date: 11/04/2018 02:34 am
Date: 09/15/2019 12:38 pm
Date: 12/13/2016 10:25 am
Date: 10/26/2020 03:24 pm
  • Online today: 447
  • Guests: 371
  • Total: 371
1974 Pinto Wagon turbo swap
Started by geobull90, May 11, 2018, 02:17:19 AM
Unless it is a deliberate drag car I doubt most run sub connectors. And even then I doubt many do. Maybe with a V-8 it would be more of a necessity.
  My turbo wagon runs the stock tank with an external Ford F-150 fuel pump (no feeder pump). It is encased in a foam lined, sheet metal housing with the pink label on it. Not pretty but it gets the job done. The return line was plumbed through the sender unit. Also it is advisable to use the factory shut off switch.
Lonny Candel
I don't know about the sub connecters. But as for ideas on a fuel cell, my 2.3T mustang has a 255lph fuel pump installed from the top into it's OEM gas tank.
90 Mustang LX w/ 84 TC 2.3 / 88 TC injectors, VAM, & computer
84 Mercury Cougar LS 3.8
81 Ford Durango 3.3
81 Chevy El Camino 350 Crate
geobull90
Hi all,
I am currently in the process of swapping the engine and tranny from an '86 turbo coupe into my wagon and was wondering if subframe connectors are going to be needed or not. Also, I was looking for some ideas to mount a fuel cell in the rear.
Thank you
