Date: 04/21/2017 02:03 pm
Date: 03/23/2018 09:23 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
Date: 10/25/2019 04:05 pm
Date: 06/07/2018 01:45 am
Date: 01/04/2017 04:07 am
Bumper Guards
Date: 03/28/2017 09:27 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
  • Online today: 1,106
  • Guests: 1094
  • Total: 1094
Need help with carb vacuum line?
Started by wilit, May 01, 2018, 10:10:23 AM
nnn0wqk
It is the port that goes to the dist vac advance on the 74's would think would be used as the same function on yours.
wilit
I think it's a timed/ported vacuum. It has a very slight draw at idle but seems to increase a little with RPM. And I'm pretty sure it's the original carb. It still has the factory tag on it.
LongTimeFordMan
Probably something to do with the automatic choke... probably to draw hot air thru the choke.
Check to see if there is a vacuum present at the port..
Does the car run ok without it? If so try putting a cap on it and see if it passes smog.
If not investigate farther.
I just moved from so cal and passing usually depends on whether you get a friendly tech. Just be polite and maybe talk about classic cars...
Also.. is the carb 5he factory one.. 5here are a lot of different models..
If the tech questions yiu about the plugged port.. tell him it was that way when you bought it.
Good luck
wilit
I'm trying to get my '79 California emissions Pinto ready for smog. In the process of doing the tuneup, I found a vacuum line on the carb that didn't have a hose attached to it. Any idea where this line connects to?
