Date: 09/01/2017 11:58 am
1976 Pinto
Date: 10/24/2017 02:00 pm
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Date: 09/02/2021 08:21 am
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Squire trim
Date: 03/28/2018 10:11 am
Date: 03/21/2017 07:47 pm
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
  • Online today: 306
  • Guests: 174
  • Total: 174
Point Gap and Fuel pume pressure
Started by dennisofaz, February 28, 2018, 11:52:11 AM
dennisofaz
Hi nnn0wqk, Thank you very much for the information!  I will try a 4-7lb electric fuel pump and see how it goes!
Dennis
nnn0wqk
Point gap is .027 with dwell reading of 35-41 degrees. Timing is 6 degrees BTDC vacuum hose disconnected at distributor. Idle 850 rpm standard 750 auto in Drive. Plugs AGRF-52 gap is .034. Fuel pump pressure between 3.5-4.5 lbs and volume would probably run around a pint in 20 seconds. Total timing advance should approach 47 degrees.  Base 6 degrees, centrifugal advance 32 degrees, vacuum 4.3 degrees. You should see total centrifugal at 4700 rpm. I pulled all this information out of a 1974 Motor auto repair manual. A little more information than you asked for but since I had the book open thought I might as well list it for you.
dennisofaz
Hi, I have a 74 Runabout with a 2.3 and I need to know what the point gap souuld be, and what the fuel pump pressure should be.  Thank you in advance!
Dennis
