Pinto drive train
Date: 06/29/2018 08:32 am
Date: 09/10/2018 10:41 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Pinto for sale
Date: 04/19/2017 10:15 am
Date: 04/14/2023 06:15 am
Front Body parts needed
Date: 02/09/2018 06:09 pm
Date: 07/01/2019 03:17 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
  • Online today: 488
  • Guests: 487
  • Total: 487
Lower Control arm bolt
Started by warhead2, February 23, 2018, 09:24:56 PM
warhead2
Thanks I couldn't find anyone on the forum that had put out the specs. And no online auto parts store had any listing even none for the
Mustang 2.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Good info.
Thanks for posting it.
warhead2
This post is for anyone who has trouble finding a lower control arm bolt and removing said rusted bolt. This is for 76 to 80. If your Pinto has sat for yrs like mine 26yrs the lower control arm bolt maybe rusted to the inner bushing sleeve. Best way to get this out is lots of penetrating oil. Try to rotate the bolt so you can see the slit in the bushing sleeve and use any type of chisel n hammer to split it open as much as you can put more oil inside the split. After it has sat try and get a pair of vise grips that will fit between the frame n control arm and clamp onto the sleeve and use a impact or breaker bar and have at it lol. But make sure the sleeve doesn't turn and only the bolt. You may hear a few snaps. So after you have gotten it out and it is not in good shape or to your liking. If you go to https://www.fastenal.com
This is the part #0142796 and the bolt specs
1/2 - 13x4.5 grade 8 flange phosphate finish. Was $5 a bolt.
It doesn't have a big taper and just a hair sorter but don't worry it will still stick out about 1/2 an inch on the opposite side.
Hope this helps.
