I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 01/30/2017 01:48 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
72 Pinto parts
Date: 12/04/2018 09:56 pm
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
Date: 04/13/2018 11:30 am
Date: 10/01/2020 02:00 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
  • Online today: 367
  • Guests: 142
  • Total: 142
2.3 oil pan
Started by Rawdawg510, August 08, 2017, 03:20:10 PM
vinnytruck,
You might want to try contacting Craig by a PM instead, as he hasn't logged onto this site since March.  You can also check his profile; there may be an email where you can reach him.  Good luck!
Dwayne :)
vinnytruck
craig, pls let me know, thanks  VT
vinnytruck
craig, do you have a oil pan??? thanks Vinnytruck
Craiggarrett1969
I might have one but I will have to make sure it's a front sump
I just use child's clay or plumbers putty between the pick up and the pan. It helps to use something like powder or oil so the pliable doesn't stretch when the pan is removed.  BTW, this works well for hood clearances too.
To check the pickup clearance what I do is to cut a piece of material 3/8 inch thick. An old magazine or plywood just so long as it fits the bottom of the sump. Then install the pan without a gasket. If the pan sits flush on the block your ok. If you want to know how much clearance you really have add more material to the sump till the pan doesn't fit flush on the block. Biggest place where the pans leak is around the drain plug. Harder to fix but doable.
I'll second that. I've only seen one or two pans that could not be fixed. Dents are easy to fix most times. Cracks are easy with a welder. A piece of 1 inch round bar stock about 18 inch's long and a BFH will allow you to reach the bottom of the sump.
Quoted from the other thread...
Quote from: Rawdawg510
looking for a 2.3l front sump oil pan to do a TC swap I have a 2.3 already but the pan it bent pretty bad. I will try to straighten it out and bang out the dents but if I cant does any one have one or knoe where to get one?
That's one thing that is very hard to find these days. I stumbled onto a 7qt race pan when I needed one, but only acquired a stock one by buying a parts car. In fact, parts cars are easier to find IMO.
Funny thing is that the 7qt race pan was made by modifying a later stock rear-sump pan. I might try that myself with the old Thunderbird pan now that I have a TIG welder.
In your case though, I would take a body hammer and dolly to what you have. Actually, if appearance isn't a big concern and as long as the pickup isn't obstructed by dents and the pan isn't cracked or leaking, I'd rather leave it alone.
The answer is on your first post of this subject.
Rawdawg510
looking for an oil pan that has a front sump for my 2.3 swap. my pan is dented pretty bad and would like a replacement one. does any one have one for sale or know where I could get one?
I tried but didn't know how to edit the title on my last thread.
1965 Ford falcon
1971 Ford Maverick
1971 Ford Pinto
2017 Ford Fusion Sport
