$300 Pinto for sale
Date: 04/19/2017 10:24 am
Custom Pinto Project
Date: 06/12/2016 07:37 pm
postal pinto
Date: 06/03/2020 09:31 am
Date: 02/18/2017 04:47 pm
Date: 06/28/2019 09:14 pm
Date: 01/24/2021 07:54 pm
Date: 02/28/2018 09:18 am
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
Date: 07/30/2018 04:32 pm
  • Online today: 481
  • Guests: 273
  • Total: 273
1971 Pinto Oil pan
Started by Rawdawg510, August 07, 2017, 06:06:36 PM
Quote from: Rawdawg510 on August 07, 2017, 06:06:36 PM
looking for a 2.3l front sump oil pan to do a TC swap I have a 2.3 already but the pan it bent pretty bad. I will try to straighten it out and bang out the dents but if I cant does any one have one or knoe where to get one?
Lots of luck! Pans are almost never for sale anymore. The Pinto club is your best bet. If the rails on your pan are ok, you can make it work. May not be pretty but that's ok.
Rawdawg510
Thank you I will change the title. Hopefully that helps
1965 Ford falcon
1971 Ford Maverick
1971 Ford Pinto
2017 Ford Fusion Sport
It might be helpful to change your title to something like: "74 and up 2.3 Pinto oil pan needed" (you will need the pick up too).  "1971 Pinto Oil pan" sounds like you need a pan for either the 1600 or 2.0. Hopefully someone will respond.  At least in the So. Cal. self serve yards Pinto's are getting very hard to find. I'd imagine in the more rusting sections of the country they are even rarer.
Rawdawg510
1965 Ford falcon
1971 Ford Maverick
1971 Ford Pinto
