Date: 02/26/2017 03:22 pm
Date: 04/04/2020 09:38 am
sport steering wheeel
Date: 10/01/2020 10:58 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
1976 Pinto
Date: 10/24/2017 02:00 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
Date: 01/23/2023 02:22 pm
  • Online today: 1,106
  • Guests: 110
  • Total: 110
Leaky transmission
Started by r4pinto, July 27, 2017, 07:05:56 AM
Easier said than done
Fix the rust asap because rust never sleeps.
Too late. Her floors need patching already
A leak a day will keep the rust away or so they say.
Except it only leaked when the car was off and not running. It happened while the car was jacked up on four jack stands lol
Just think. After the tranie oil leak, you need not worry about rust under the car for a while.
You got that right. $1 in cat litter, $1 in a new drain pan so no contamination, $.29 for a new dipstick seal, and 3 quarts of type F at $5.69 a quart. Bought three but used one, so technically only $5.69. I bought the new gasket but since I don't need it I will return it.
1972 Wagon
It makes you feel good when you solve a problem, especially if it doesn't drain the bank account! Pat yourself on the back and say, "Mission accomplished!"
*The Original Family Car: A 1972 Pinto Wagon*
Ordered by my folks from Bunnell Motor Company, Inc., Bunnell, Florida
Delivered: June 20, 1972
Entrusted to my care: August 1976
Leak is fixed. I installed a new dipstick o-ring, and when I removed the pan found a 4 inch long strip of old gasket. I don't know how I missed it but it caused the massive leak. I was able to save the transmission fluid since it was not old, and put it in a brand new drain pan, then poured it back in the transmission. Only lost about a quart but it looked like a lot more. So far so good.
Check the hose/tubing that goes to the front. Also the vacuum module.
Hey guys,
Got a major issue. Well, major in my eyes.
Last night I got home and saw the garage floor covered in fluid. Transmission leaked everywhere.  The car is a 1980 Ford Pinto Runabout..... Anyway, I replaced the transmission pan gasket since it had leaked before due to an old, cracked gasket, and also replaced the tail shaft seal since it was old. The transmission is a C4 automatic. I've been told they did not come with a C4 in 1980, but according to the door tag it is a C4 from the factory.
Anyway it isn't leaking from the rear of the car, but from the front of the pan. I've ordered a Fel-Pro gasket for the car and will be replacing that tonight. Any suggestions what else it may be?
