1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Date: 02/11/2020 12:09 am
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
Pinto drive train
Date: 06/29/2018 08:32 am
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
Date: 02/04/2018 08:26 am
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Date: 08/08/2018 12:26 pm
  • Online today: 1,106
  • Guests: 169
  • Total: 169
rear end
Started by Loner, July 09, 2017, 10:33:34 PM
My 80 Pinto with a 6 3/4" rear end has a square shape cover on the rear end. Check the bolt pattern on the axles to see if its 4 1/4".
Quote from: Loner on July 09, 2017, 10:33:34 PM
8 bolt, square pan. (not octegon)
That tells me it's not a 6.75in Pinto rear end. Pintos only came with two options: either a 6.75in integral carrier (with an eight-sided cover) or the ubiquitous Ford 8in with a drop-out third member.
I have a 6.75 diff and axles I'm not going to use, but wouldn't stock Pinto axles be too wide for a trike anyway?
In reply to the other post where you stated you were confused. http://www.fordpinto.com/general-help/rear-end-by-loner-(reply-to-locked-thread)/msg175065/?topicseen#new
  I'm not sure what has you confused? But, I will basically restated what I said before incrementally.
1. There were two different rear ends used in Pinto's.
2. One type is the 6-3/4" which sounds like what you describe. There is a removable rear cover. However, a picture would be helpful to decide that is actually what you really have. Or, you can do a Google image search.
3. The other type is the 8", it has a smooth rounded cover that is not removable and the gears are accessed by a section removable from the front.
4. There are no specific Pinto parts dealers like there might be for a classic Mustang or Camaro. There are a few individuals that sell parts they have acquired.  Asking specifically here would be a start but frankly this board has very low activity. So, you may not get any response, or it may take some time. Update - Case in point: 48 hours have passed (see image) since I replied to your initial, locked post with a separate post..., Dewayne the Administrator then unlock and moved your post and I have re-answered your post at this new location on the Forum. In that 48 hour time period the three most recent posts are all three of those actions. Like I said, it can be slow.
5. It is likely difficult to find someone just selling the axle or spider gear.
6.  You would probably more easily find someone selling a whole 6-3/4" rear end but that is a heavy item and costly to ship.  If you let people know where you are located (in general) you have a better chance of getting a reply if they know you are near by.
Loner
Hi All.  Long story short I have an old Lehman trike. I have a problem with the rear end. Was told it was early Pinto. I need left axle and spider gear. But not sure witch one it is. What i have. rear drop out, 8 bolt, square pan. (not octegon) 4 lug with drum brakes. I also think that it is 2.73 gears. Any ideas?Would rather talk on phone if possible. Took me all afternoon to get this far.
   Loner  559 310 5792
