Hatch needed
Date: 09/10/2017 09:16 pm
Date: 06/30/2018 09:48 am
Date: 09/10/2018 10:41 pm
Date: 07/13/2018 02:21 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
Date: 12/20/2016 10:47 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Date: 05/22/2018 01:54 pm
  • Online today: 1,106
  • Guests: 187
  • Total: 187
swiftfork missing!
Started by carlo bikkel, June 28, 2017, 10:55:51 AM
carlo bikkel
Thanks for that! I have contacted the guy and he is convinced he is able to help me out. many thanks! :)
robertwwithee
Wow, you two definitely need to get together.
72DutchWagon
Hoi Carlo, I'm also in the Netherlands and there is much more knowledge on Ford T9 gearboxes (which I think it is) in your direct vicinity then you know about. I know a guy in the neigbourhood of Nieuwleusen who had several of these lying about with broken tailpieces (happens a lot in banger racing). He might be able to help you out, I'll PM you his phone number.
carlo bikkel
Hi all, I am new here at the forum, joining you from the netherlands. Unfortunately there is not enough pinto knowledge here to help me with the following problem: I have a kitcar with a pinto gearbox (id code RF-D42R-7006-AA). The gearbox itself seems to be OK but the part needed to get the gearlever/gearshift in is missing. on the third picture you can see the wire end/stud bolt/thread end (not sure what you call that) which should hold the part needed before you can put on the gearlever. That part problably will be held by a nut and the two flattened ends on the wire end will enable me to move from 1st to 5th gear (so from left to right).
I hope the question is clear, but feel free to ask all that is needed to hopefully get an answer. There is an 8 hour or so timedifference between you and me so a short delay is possible.
Many thanks for your time!
Carlo
