Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Date: 01/20/2018 07:51 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Crane Cam
Date: 02/26/2018 07:50 am
73 Runabout
Date: 11/20/2017 03:19 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
parts needed
Date: 02/20/2017 07:58 am
Date: 10/24/2018 07:41 am
73 rear hatchback glass
Date: 07/06/2017 11:33 am
  • Online today: 489
  • Guests: 384
  • Total: 384
Weather Seal/Striping Set Doords & Windows
Started by C. M. Wolf, June 09, 2017, 03:37:38 PM
Thanks for clearing that up.  The bottom section seems the most difficult to seal.  I'm tired of the fumes. I'll be looking into it shortly as I'll be going by Pick Your Part tomorrow.
JonzWagon
I have an '80 wagon, and 3 years ago I used a door seal off an 1998 Ford ranger to replace the seal on my wagons rear door. It has the same profile (important) and was a couple inches longer. It works perfect.................seals great. A new one from a dealer is about $20........so a junkyard is a good bet. Reg. Cab Ranger doors 1998 thru 2010 are the same. ;)
Unfortunately that post refers to a hatch and is different than the rear door on a Wagon. After the rubber slides over the pinch weld it needs to go a fair distance to the rear to seal at the bottom.  I found something in a late 90's Cadillac and thought it might work, but it still comes up short. And, after looking at MANY cars that was the closest I could find.
warhead2
Another post says you can use a 98 extended cab Ford Ranger door gasket for the rear wagon hatch.  will be few inches longer so one cut. http://www.fordpinto.com/parts-resources-here-is-where-you-can-find-this-or-that/ford-pinto-wagon-rear-door-gasket/msg119367/#msg119367
Sent from my SAMSUNG-SM-G930A using Tapatalk
I took a look at Steele Rubber quickly. Yikes. Looks like to would cost more to re-rubber a Pinto than many have paid for them! http://www.steelerubber.com/search?year=1973&make=ford&model=pinto&style=2-door-wagon
Glad I pulled "better than what I have now" rubber out of Pinto's at about $3 a piece when I found them at Pick Your Part. I didn't recall seeing a rear hatch seal for the wagon. I've looked at a lot of seals in the yards and the one I thought came the closest to the Pinto still missed by quite a bit. So, finding something to work there is going to be a chore.
If money is an object you might find other cars that do have something adaptable.  The 1st Gen. Mazda MPV has door seals that resemble that typically used on a lot of 60's/70's cars. I used them on my '64 Studebaker. Even though over 15 years old the rubber was very good and at $3 a door it was a good fit for my wallet.
C. M. Wolf
I'm sure this has been asked before.. but I need a complete set of side door & rear door & all window & windshield rubber for my 73 Wagon. It now has has the Porthole Panels so I don't need those window rubber. What's the best and the most cost effective place to buy new? I thank you all in advance.
Michael
