Built 2.0
Date: 10/07/2018 05:27 pm
Date: 01/20/2018 07:51 pm
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Date: 12/15/2018 02:21 am
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Date: 01/21/2023 04:19 pm
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
FLOOR PANS
Date: 06/12/2020 07:24 pm
Date: 09/20/2018 11:01 pm
  • Online today: 2,399
  • Guests: 1555
  • Total: 1555
77 bobcat
Started by phils toys, May 04, 2017, 08:22:33 PM
Working on a Pinto or Bobcat is so easy compared to a modern day car. I can not even see the spark plugs on my new Suburban. A screw driver and plyers will do most of a Pinto / Bobcat daily maintenance. SO EASY.
Quote from: phils toys on November 25, 2017, 10:15:17 PM
It is in the garage for winter. My son has the head at school rebuilding it.unfortunately not much room to work on in garage with 2 cars
However the difficulty is made easier knowing they are a Pinto and a Bobcat!
Glad to see all is ok. Keep us informed about your cars.
He must have fixed it because he quit posting. Hope its really fixed and not just parked.
Pintopower
Any updates? I love Bobcats!
#1. 1979 Wagon V6 Restored
#2. 1977 Wagon V6 Restored
#3. 1980 Sedan I4 Original
#5. 1980 Wagon I4 Restored
...Like i said, I like them.
...and I have 4 Fiats.
May want to check the rear hose. If it's old it might be collapsing which could lock up the rear brakes.
Went for a drive yesterday about mile into it the brakes locked up again. Took a lot but finally got home. Today check the rear brakes. Rebuilt the drivers side. Then played under hood. Adjustments on carb. Idles better  don't bog down as bad, but still has a "flat " spot about the time it shifts and still will not go over 60 mph. I guess I should take carb apart and check for garbage.
I like the blacked out look. Looks slick. Did you ever consider painting the wheels black with a red line to go with the color combination of the car?
No hole in fender of wagon.
This has an am only radio. Plan on upgrade.
All three of my 80 Pinto pony's came with the delete panel but with the antenna hole drilled in the fender. Had a plastic cover over the hole.
His bobcat villager wagon came with the radio delete.
Every Pinto pony I ever saw in a dealers lot had a radio delete panel. Just the pony cars.
Looks like a nice ride Phil. Does this one have the radio delete option like your wagon?
A few more changes
Looks really good Phil. You bringing this one to the show in Geneva as well as the wagon?
What color and what kind of spray paint? Looks very good.
Doesn't look bad at all and there is a lot to be said for consistent color!
Dwayne :)
It is only a 20 ft paint job  but consistent color. Just spray cans for now.
Doing some nice work to the little car Phil. What did you paint the car with?
Phill. Looking good like a Pinto should/ Keep up the good work.
Raining today  in between drops here is one side
One on
Yes  I'm not comfortable welding  .new tires and rims go on tomorrow. Engine parts on the way. Still have interior to work on.
Nice job so far Phil. Did you have the floors welded in professionally?
JoeBob
congrats Phill
I also have a 77 bobcat. You might be interested how I drew in my bumpers to make a better looking car. The original instructions are here. http://www.fordpinto.com/your-project/simple-fat-bumper-fix/
Good luck with your car.
77 yellow Bobcat hatchback
Deuteronomy 7:9
Found rims started restoration on one also changing center caps
Spray a lot of water on the front windshield and cowl area , make sure these know places do not leak and have a chance to rust out the floor in the future , better check now than cry later , wet carpet will rot faster along with the floors , ask me how I know  :o
