Date: 07/20/2017 01:23 am
76 drivers fender
Date: 07/20/2018 08:24 pm
Date: 08/09/2018 07:49 am
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
Bumper Guards
Date: 03/28/2017 09:27 pm
Date: 12/13/2016 10:25 am
1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
parts needed
Date: 02/20/2017 07:58 am
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
  • Online today: 248
  • Guests: 121
  • Total: 121
HEADLIGHT AND WIPER SWITCH KNOBS
Started by chriss, March 30, 2017, 07:25:41 PM
chriss
Thanks to all..  I'll give it a try, should be easy, as I have the cluster and dash pad off anyway..   as far as the knobs on e bay go, they must be the second design, because mine has the light and wiper/ washer symbols on the face of the knobs.   Chris
1971 Pinto sedan 2000cc      1969 Plymouth Satellite 4dr slant 6  69k miles      1980 Olds 442  1 of 886.     1992  Mustang LX 5.0 convertible, 1987 Camaro convertible 1 of 263. 1995 Z28 convertible 21k original owner . 2008 Silverado. 2016  Camry  s/e
Pinto1600
I was just E-bay and someone had the switches and the knobs for sale. Put in ford pinto knobs and they should pop right up!
Happiness is..Driving a classic Pinto
robertwwithee
To pull shafts and know off, pull out instrument cluster and push spring release button on top of switch behind dash.
To just pull knob, on the side there is a cut out for a small object to fit into.  Place screwdriver on the end and  Pull in towards u and you'll release metal tab from shaft.
My 72 has 73 HL Switch adapted, but I believe it still pulled off the Shaft. If in doubt, pull switch out to on Position ,then using 90 degree needle nose pliers grab the shaft behind the knob to take the stress off the switch assy internally, Then pull straight out , holding the shaft still so the switch internals aren't damaged. If you still see no movement, and that doesn't release, Stop then look for a retaining pin at the knob base. As old as the plastic is, be careful it doesn't break into pieces. Some German cars (Vw for instance) have a Button to be pushed in the back of the Switch and the whole shaft and Knob pop out in one piece.
If you have no success, stop and rethink how you approach this, nothing more disappointing than having broken parts in your hand.
Pintosopher  A Knob would never get the Lights on in this Mind ;)
chriss
Since I can't find nos  knobs for my '71.  I called a place that specializes in chrome plating and he said that he can redo them. can some one tell me how the knobs come out of the switches?  it looks like the wiper knob may just pull off the shaft, but I don't want to destroy it.   I  guess Ford changed part numbers for these knobs as of 6-15-71.  my car was built 6-7-71 .
