1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Date: 09/03/2018 08:58 am
Date: 10/25/2019 04:05 pm
Date: 07/30/2020 11:45 am
McLeod Clutch
Date: 04/12/2017 12:08 pm
Date: 04/04/2020 09:38 am
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
  • Online today: 367
  • Guests: 169
  • Total: 169
oil pressure sending unit
Started by robw, August 17, 2005, 12:17:17 AM
Quote from: Pintony on August 23, 2005, 08:36:17 PM
OK, Keep your silly secrets
I'm not going to bother with searching???
It is just good to know that I'm not the only one to be wrong.
ONCE IN A WHILE!!!!!
;) :D ;D
Its a secret, Like my gas cap................. ;)
What subject and catigory are those posts in???
Tony, go back and read some of my posts where I confused the two................. :o :o :-\
OOPS! was I thinking 2.0 again???
Somebody help me out here???
robw
I found an old sending unit on the back of the block in the head and took it out and it had oil in there so I hooked it there.seems fine, does it really matter if it is there or under the intake.thanks :-\
Hello robw,
Yess! that is the correct location.
Under the 2.3 intake manifold.
You will need a special socket to remove that sucker though.
You may get lucky if you can get on the sender with a box end 12 point wrench
22MM I think????
robw
I've got a 80' pinto with a 2.3 and am trying to hook up a mechanical oil pressure guage but can't find where it goes i think it is under the intake(a big mushroom shaped thing),but am not sure any help would be appreciated. and where did you guys mount your guages in your car. thanks
