Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 08/02/2019 04:18 pm
1980 Ford AM radio
Date: 12/22/2019 11:57 am
Date: 03/27/2017 10:07 pm
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
Date: 01/20/2018 07:51 pm
Electrical
Date: 03/29/2017 11:37 am
Drip rail chrome
Date: 01/14/2017 09:18 am
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
  • Online today: 1,106
  • Guests: 152
  • Total: 152
Starter
Started by djspinto, February 02, 2017, 08:33:11 PM
It is a typical way of testing.  I'd add that the motor can torque rather forcefully and the starter needs to be properly held. When you say, "hooked up a cable" by what means were the connections made?  Was the cable bolted to the battery and starter both at the + terminal and when grounded to the starter case?  I've tested starters using jumper cables and have found that unless the cable clamps and place I'm connecting to are VERY clean I often don't get a connection.
But, frankly from your description of "getting sparks" it leaves me incline to say the current is getting through. I have found there is sometimes a delay (under a second) from the point of current application to the point of the starter solenoid engaging and powering the motor.  So, if you are merely tapping the connection for a split second you may not be getting engagement.  Otherwise it would seem the starter is shorted so don't hold the connections for longer than a (real) second as the overload can get dangerous.  Proceed with caution at your own risk.
djspinto
I just got my new (rebuilt) starter for my 2.3 Pinto, and decided to bench test it before putting it on. I hooked up the positive cable from a 12V car battery to the positive (starter) terminal, and I hooked up the negative (ground) to the frame where it gets bolted to the engine. I got sparks, but the motor did not turn and I couldn't hear any clicks.
Is this the proper way of bench testing a starter, or am I doing something wrong?
Or.... Is it possible that I got a defective rebuilt starter?
The starter is a ACDelco from Rockauto.com. Part #3361012
Thanks
