Date: 02/21/2017 06:29 am
Date: 03/16/2017 10:00 pm
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
Date: 09/01/2017 07:52 am
  • Online today: 1,106
  • Guests: 115
  • Total: 115
9" rearend
Started by azz101462, January 29, 2017, 07:02:46 AM
'57-59 fullsize Fords, '65-66 Mustangs, Mavericks, Pintos, and I think even Fox3 Mustangs ('79-93) all have the same rear end width. You might find one in a Granada-based '70s car since they were also built on that old Falcon platform.
'67-68 Mustangs are wider by about 0.75" per side. I have a '58 Ranchero 9in in my '68 Mustang and the wheels are visibly tucked in. Funny thing, I had a '65 Mustang with a '67-68 Mustang's 8"(not my doing) and the wheels stuck out. It was promptly replaced with a Lincoln Versailles 9in. 8)
As an FYI, a regular two-pinion/28 spline 9in isn't going to be stronger than a similar 8in. For all the difficulty of getting a 9" into a Pinto, it may be more worthwhile to retrofit a '91-98(?) Explorer 8.8. It's going to have 31 spline axles already and at least 3.73 gears if not 4.11s. '95+ have disc brakes, so that's an "easy" way to get rear discs at the same time.
http://www.therangerstation.com/tech_library/Explorer8_8.shtml
azz101462
Thanks for all the info, it does help and still searching for a rear end.
Yes its a C4 Auto with a soon to be manual shift, reverse pattern with possibly a trans break (not sure about that just yet).
pinto1955
57-59 Full size Fords, Mercury, and Edsels will fit nicely. You will need to move the spring perches. I believe the measurement is 42 1/2 inches from center to center on the perches. I just finished putting the same rear end in my wagon. Only drawback is that it's an open 28 spline but I put a spool in mine. I ran one of these in my drag car for years and never had problems. Hope this helps.
1972 Ford Pinto SS/MC, HP 2.0, 4 speed, 9" full spool w/6:50 gears
A 9inch from a 65-66 or a 67-70 Mustang will fit with a slight modification to the spring perch. The widths are slightly different between the two sets of years, I believe the 65-66 are closer to the Pinto stock width.
I believe if I remember correctly that a Maverick rear will also fit with little work, but again very rare.
However, these aren't that cheap
Might be cheaper to go with a Currie or Moser rear that is made to your exact measurements.
Or get one out of a pickup or other model Ford and have it narrowed and spring perches installed.
I don't think there are any 8.8 rears close to fitting without mods, and none came with leaf springs. I personally hate these rears anyway, so I don't pay attention to them.
Lots of people will tell you that an 8inch would be plenty. I am of the opinion that more is better and overkill is perfect.
When you say C4 manual, are you talking about a manual shift valve body in the trans, as the C4 is an automatic.? My end goal is now a Toploader with a Gear Vendors overdrive.
azz101462
1974 Pinto Wagon.
well my son and I have beefed up the engine (stroker 408) and decided to swap out the T5 to a C4 manual, now we are in the market for a 8.8 or 9" posi that will bolt in without too much fabrication. does anyone have any suggestion on a replacement rear end?
