2.3 pinto carb
Date: 08/18/2018 02:07 pm
Date: 04/10/2017 07:30 pm
Date: 10/10/2019 09:42 pm
Date: 02/08/2018 02:26 pm
Date: 06/25/2021 12:59 am
New cam
Date: 01/23/2017 05:11 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Date: 06/24/2020 06:12 am
  • Online today: 489
  • Guests: 129
  • Total: 129
My pinto rear end ratio change and posi unit
Started by pinto_one, January 27, 2017, 02:28:16 PM
after I got the pinnion tourqe done with I reinstalled the carrrer and shimed the pinnion gear to have the right gear contact , the pattern will end up like this when you have the back lash right and the right shim in place , after I recheck all the bolts for correct tourqe ,  the five pinnion bolts (3/8 ) 45 ft lbs ,  carrer bearing caps 60 ft lbs ,  the ring gear also 60 lbs ,  now all complete ,  next I will post changing of the axle bearings ,  next project is assmbling a cust 520 cubic inch 6 cylinder aircraft engine ,
got it all together ,  installed new pinnion bearings and a new crush sleave , which is a must for correct pinnion preload , which 10 to 14 inch pounds to turn the pinnion , sorry for fuzzy photo there , but you get the idea ,
Tomorrow I will be finishing it up and posting more photos , hopefully this weekend I will install it  ;D
Well got some progress today, took one of my spare third member from a rear end and cleaned it up , along with the axles , installing new bearings there also along with the seals ,  bead blasted and painted up the unit and installed the pinnion nose bearing in the case , mounted the ring gear to theposi unit with new bolts , a dab of lock tight on each and torque to 60LBS , droped the carrier into place and and install caps , they also torque to 60 also , would have done more but forgot the pinnion shims at home so guess it will have to wait
Yes please, I am currently struggling thru an 8.8 rebuild.  Might learn something new from you LOL.....
Just got in some new parts for my pinto , new 3.40 gear set and a yukon HD posi unit along with a overhaul bearing kit , thought about posting the steps on assembly of the third member if anyone thinks it a good idea , Later Blaine
