Date: 11/29/2018 10:26 am
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
Date: 02/27/2017 10:10 pm
oldskool787
Date: 02/12/2017 12:42 pm
Date: 09/01/2017 07:52 am
73 rear hatchback glass
Date: 07/06/2017 11:33 am
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
72 pinto drag car
Date: 07/08/2017 08:53 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
  • Online today: 1,166
  • Guests: 1074
  • Total: 1074
Any Tips on Replacing a Washer Fluid Pump?
Started by 1972 Wagon, January 23, 2017, 01:23:54 PM
robertbrann18
Quote from: 1972 Wagon on January 25, 2017, 05:36:05 PM
Wow! I can see why the pump didn't work. My original pump just had a small discolored spot on the side. Glad that you got the new pump installed.
I'm definitely glad I changed it out, probably was never changed. Thanks for your information, it really helped a lot.
1971 Blue Ford Pinto Trunk Model
1972 Wagon
Delivered: June 20, 1972
robertbrann18
Out with the old
In with the new
robertbrann18
That's good to know, thanks for the info. I'll probably just do the same and use water.
1972 Wagon
Glad that I could help! The directions say to lubricate the rubber pump seal with dry lubricant (powdered graphite). I assume this is to make the pump slide in easier. I didn't have any so I just moistened it with water. The pump also comes with a new retaining ring.
robertbrann18
Lol, thanks for the information! I just ordered it and should be here tomorrow. I pulled out the jug and it's nothing but slush where the pump is. Hopefully that's the reason why my windshield washer isn't working.
1972 Wagon
My receipt says #368829, TAAP 7-664. The washer pump was $12.99. My AutoZone had to order it and it was there at 10:00 AM the next day. There were only a couple of AutoZones within 20 miles that had the part in stock. The washer pump was identical to the original which was never replaced before. I know this because the car has been in my family since 1972!
robertbrann18
Quote from: 1972 Wagon on January 23, 2017, 01:23:54 PM
I have to replace the original washer fluid pump in my 1972 wagon. The pump is located in the bottom of the washer fluid bottle. Thanks to a 2011 archived topic between blupinto and Dave1987, I was able to find an OEM pump at AutoZone (O'Reilly's was more expensive!). Does anyone have any tips on how to install the new one?
What was the part number for Autozone?
1972 Wagon
Thanks for the help, Tigger! The new pump went in much easier than I thought that it would. For the first time in years, I can now squirt cleaner on the windshield.
I think it is as easy as bending the tabs back on the retaining clip thing that looks like a huge lock washer.  Removing it.  Removing the bad pump.  Install the new pump.  Reinstall the retaining clip and bend the tangs back.  Hope this helps some.
1972 Wagon
