Date: 12/09/2018 06:59 am
Date: 02/28/2018 09:33 am
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
1978 hatch back
Date: 11/29/2019 03:18 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Date: 10/26/2020 03:24 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Date: 02/08/2018 02:26 pm
  • Online today: 178
  • Guests: 180
  • Total: 180
1974 Ford Pinto 2.3 Spark Plugs
Started by robertbrann18, January 02, 2017, 08:41:44 AM
Amazing what a fresh set of plugs will do, huh.. :D
robertbrann18
Changed the spark plugs out and my Pinto runs amazing! Gap was correct and no misfire. Just got to start working on the carburetor now.
1971 Blue Ford Pinto Trunk Model
robertbrann18
Quote from: 74 PintoWagon on January 04, 2017, 06:57:23 AM
That would be right for a stock point system..
Awesome, thank you!
robertbrann18
I have a point type distributor and from what I can gather from the web, the default is .034.
All depends on if you have a point type dist or a later dura spark. Point dist will be a closer gap of aprox .025 with .035 for the dura spark dist. Fireing order is cast on the top of the intake manifold. (I think). Gap will not make a big difference on the dura spark unless its gaped at 1/8" or zero. The dura spark system will jump a wide gap where a point dist will miss if the gap is too wide. Always start on the low side as the gap will get larger with miles on the car/engine. Best thing you could do is convert over to a dura spark if you have points.
robertbrann18
Changing out the spark plugs now for my pinto. For best performance, what should I gap the spark plugs at? Also, someone told me the firing sequence is 1-3-4-2, is that correct?
