Date: 05/13/2021 05:33 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
Date: 10/05/2017 02:26 pm
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Date: 12/10/2016 04:11 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
  • Online today: 1,166
  • Guests: 1087
  • Total: 1087
Mystery part question
Started by 28trackT, December 16, 2016, 03:37:50 PM
robertwwithee
Very nice
I aways removed the valve when the diapram went bad, "you put your finger over the hole in the middle of the small plate and you had vacume" you unbolted it from the manifold and used a large allen wrench and removed the swivel nut from the intake manifold , yes it takes a allen wrench on the inside , then you remove the nylon part that screws into the top of the valve and use that as a plug , same threads , the small 1/4 hose you plug at the carb , it was in a vent part of the carb , not needed , car will run the same and not have that high idell anymore ,
28trackT
Thanks for the info. And here's the Track T
Before I swapped to a 2.3 the 2.0 in my 73 wagon likely had the decel valve. "Had" meaning when I got it, it was no longer installed. The simplicity is that anywhere there is a vacuum line it will need to be plugged. I do not know if there are secondary consequences. There may be a propensity to backfire or possibly stall, run rich (or lean) etc. So, whatever, you choose to do, do at your own risk. The link in post #3 I recall gave some information that might be helpful. As best I can tell the decel valve threads into the intake, and would seem to need a threaded plug upon removal. The air cleaner is likely the intake source and should be plugged there as well as the vacuum line that probably originates off the carb or intake manifold.
28trackT
Hi again. I read the post from some time ago and I'm curious as to how I can eliminate it. Any help is appreciated.
28trackT
Hi and Merry Xmas. Yes that's the part. Is there a way to simplify? Any diagrams?
I assume you are referring to the De Cel (de-acceleration) Valve (see image). They were a smog device that came into play when the throttle was let off. The following link has a discussion regarding it. http://www.fordpinto.com/index.php?topic=6330.0
robertwwithee
I think he might be talking about the decel valve which is the square top about 3 inches in height.  Is that it 27TrackT?  If so yes.
Which part is the part your question ask about? I see about 7 or more parts in the picture.
28trackT
My 2.0 engine/carb set up started in California back in the late 70's. Can anyone identify this part please and can I eliminate it?
