1976 pinto for sale
Date: 01/12/2017 02:08 pm
Date: 04/20/2017 10:10 am
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
Date: 11/05/2016 09:03 pm
Date: 10/02/2017 02:16 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
door sills
Date: 03/14/2020 03:20 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
Date: 03/07/2017 07:03 pm
  • Online today: 1,166
  • Guests: 1095
  • Total: 1095
ANYONE RECOGNIZE THIS LEAK AREA?
Started by fastfred, December 13, 2016, 10:30:38 AM
fastfred
If you can get a second set of hands in there pressing inward on the servo cover it may be helpful in getting the "C" clip out. Sometimes this takes a pry bar and a block of wood to pivot off of. It likely won't move inward much, but it should be enough to get the clip out with less difficulty. Also, make sure when you reinstall the servo cover with the new seal that you lubricate it so it slides in.  Otherwise the rubber can grab and roll in the groove pinching the seal and then your back to leaking again.
fastfred
Intermediate servo cover, any trans shop will have a seal..
I used the term "generic" description because I did not know initially the specific transmission. But the servos all function pretty much the same.  My guess is that all the seals are showing their age and this one is just showing because it is external.
However, as I stated there are internal seals that go with the servo pistons as well. If your going in that deep you might as well replace those too. I say that with the caution that the internals of the servo can sometimes get complex - but it doesn't look that way for the C3 (see image). Also, depending on the available transmission tunnel clearance you might not be able to get the servo all the way out before it hits the tunnel. You should be able to find the seal separately, but sometimes they are only available in transmission rebuild kits (as in you have to buy the whole thing). As best I can tell you have a C-3 transmission. The part in the image for the external seal is 362. The servo piston (seal looks integral) is 902. Note these are NOT the part number, but just the number in the image for illustration. You will need to find the part by application and the box brand stores might not carry it. It is possible that you will have to go to a transmission parts vendor.
fastfred
That was very helpful. Many thanks. I have a new pan gasket, not a cork one though, I am pleased to say.  I will source new seals.
Any one know part #'s?
Fred
That is one of the servos for the application of the transmission band. No, it is not threaded in. It is held in place with a "C" clip.  If you look at the image circled in red there are two ends of the clip. A tool like a thin screwdriver is used to capture the end of the clip and then pry it upward and then outward out of the internal groove it sits in. You need to re-position the screwdriver as you work your way around. When it is removed one of two things will happen. Either near the end of the "C" clip removal the center piece will pop out with some force (it is spring loaded) and ATF will run out.  OR..., even after the clip is removed the servo cover will hang up and you will wonder how it will ever come out. Usually tapping on it causes it to free (with the same popping out results listed above). Basically what can happen is the "C" clip removal causes the servo cover to cock in the bore and hang up.
There is a seal on the outer cover and a seal(s) on the inner piston. Removal of the piston may also contain a rod.  Depending upon the band application hardware you may have to drop the trans pan and the valve body to re-position the attachment piece.  This is a generic description and the servo internally may be more complicated than I describe.
fastfred
As the photo shows there is a leak from the round section just above the right hand side just above the transmission pan on my 2.3 Pinto motor.
Does this section screw in place and is there a seal in there?
Thanks in advance for any replies.
Fred
