Crankshaft Pulley
Date: 10/01/2018 05:00 pm
McLeod Clutch
Date: 04/12/2017 12:08 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
Date: 12/31/2017 09:03 pm
Esslinger 2.0 intake
Date: 03/06/2017 11:58 am
Date: 02/28/2018 09:33 am
Date: 03/07/2017 07:03 pm
74 hood
Date: 07/03/2017 03:46 pm
  • Online today: 1,166
  • Guests: 1065
  • Total: 1065
THROTTLE ACTUATOR 77 PINTO W/2.3
Started by qq2ofus, November 13, 2016, 12:13:13 PM
I do not have a 77 Pinto, so I am not sure what you are asking.  If you are asking about the wire to carb electric choke heater, my 77 schematic shows it as white with black hash marks.  The wire is one of the wires tying the voltage regulator to the alternator and to the choke heater.
If your 77 Pinto has the Sports Option, the carb choke heater wire comes straight from the alternator and is white with pink hash marks.
The 77 Pinto schematic also shows a carb throttle solenoid with red with yellow hash mark wire that is hot when the ignition switch is in the run position.
The 77 Pinto schematic also shows a carb valve control solenoid with a red with light blue hash wire from the starter relay.  It has a second wire white with pink dots going to a coolant temperature switch.
qq2ofus
I have a 77 Wagon, I am finishing, I finally have the fuel issues resolved (set to rich) Now I need to add an actuator to the carb as it is an auto C-4 It has an electrical connector , and I havn't a clue where to hook it up, I have the vacuum hooked up it goes to an electrical vacuum control on the firewall, yellow in color, one vacuum line goes to the manifold to the controller, while the second vacuum goes to the actuator itself, It all will not work till I figure what color wire on the harness it connects to !  CAN ANYONE HELP HERE ?
Thank You
I'm a member of the Pinto club, driving pintos is what I love  I don't like ol' pickup trucks, I'm a member of the Pinto Club
