Seeking parts
Date: 10/18/2020 10:35 am
Date: 09/15/2019 12:38 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
Date: 06/05/2018 09:13 pm
Date: 10/03/2018 02:00 pm
Date: 08/03/2017 07:40 pm
  • Online today: 1,185
  • Guests: 494
  • Total: 494
Heater Delete Plate
Started by Reeves1, November 01, 2016, 06:22:09 AM
For clarity the MG fan I used needs to run backwards (simply reverse polarity) and I used the MG fan cage also. The cage spins backwards but I felt it moved sufficient air. But, do note I live in So. Cal. and heating requirements are lower here than other places. As is obvious this was necessary for a Turbo 2.3 swap, but I see you are doing a V-8 swap.  I agree with Jerry (Old Kayaker) there are many options with heater motors. Mounting  the motor is relatively simple as they typically only have 2 or 3 screws.
I stumbled upon the MG fan only because we used them as replacement motors in our Sunbeam Tigers. I had done the swap, but never put the housing back in the car.  Then when it became obvious the Pinto needed clearance ... the rest is history.
For a shorter blower motor, Wittsend used a MG Midget motor and JohnW used a 89 Turbo Carvan motor, see links.  I have not seen it done but maybe using a radiator electric cooling fan pancake motor with some R&D.  Pinto's with factory AC had the blower motor located inside the car and a flat engine bay cover where Freon pipes enter, see ebay photo (I do not see the second hose but it gets the idea across).
http://www.fordpinto.com/index.php?topic=22899.msg139619#msg139619
http://www.fordpinto.com/index.php?topic=24959.msg152749#msg152749
Maybe. You can see I posted asking for info: http://www.boss302.com/smf/index.php?topic=73661.0
Thoughts ?
I've searched all over for a short (flat ?)motor. No luck. Even called GE asking & they said without a part number, no go , as they would have to look at hundreds to match up.
