Date: 02/18/2017 04:44 pm
Date: 05/13/2021 05:29 pm
Esslinger 2.0 intake
Date: 03/06/2017 11:58 am
Date: 03/27/2017 10:07 pm
Date: 07/01/2019 03:17 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
pinto for sale
Date: 09/11/2016 09:47 pm
Date: 08/05/2018 01:58 pm
Date: 08/03/2018 09:19 am
  • Online today: 267
  • Guests: 266
  • Total: 266
Someone school me on 2.8l
Started by ccrain, October 31, 2016, 09:34:42 PM
When I worked at the dealer back in the 70s most people thought they were just nosy engines , the 1600 , and 2.0 pinto engine had to have valve adjustment also , but most were never done , the bronco II up until 85 had the 2.8 also , next door neighbor had one and believed his dumb buddy's that the lifters were going bad and the engine was going to blow up any day , show him how to adjust the valves and do it every 15k miles , not every 60k , I adjust mine every 10k ,
DBSS1234
These motors are solid lifter engines so the valves do need adjustment. Follow instructions in a shop or Chilton's manual and the ticking noise should go away. A lot of people did not realize these were solid lifter enginse so the valves were not adjusted as needed.
ccrain
The 77 pinto squire wagon I aquired this weekend has a 2.8. Has a noise coming from left hand cylinder head.  A tick like a lifter out of adjustment.  Are these noisy motors?  Any luck a valve adjustment will quiten it down?  Motor is slick as a button other than tick.  Going to put valve cover gaskets on this weekend and check valve adjustment.  I've got a motor manual that says get #1 tdc adjust, rotate 120 degree each time following firing order.  Seems pretty easy to me.  I guess I'm going to run motor till something happens to it of I find a 302.
