1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Date: 12/09/2018 06:59 am
2.3 carb intake
Date: 07/15/2020 09:25 pm
Date: 02/18/2017 04:41 pm
Wheel cap
Date: 04/25/2022 11:21 pm
Date: 02/14/2018 01:34 am
Date: 09/20/2018 11:01 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
  • Online today: 1,166
  • Guests: 1039
  • Total: 1039
battery hold down
Started by LEL, September 08, 2016, 08:21:22 PM
It also can vary due to what engine is installed. I-4  1600  and 2000 (2300 was later) and/or V-6 for example .So what is needed is what year, what engine and if it had other things like A/C even if it was dealer installed "could" make a difference. I hope this helps.
I don't have pics but one is offset compared to the other. Depends on what year your car is as to which one will be correct. As for attaching to the fender do it whatever way you like. On my 77 the threaded part was long gone so I just put a bolt in back but on my 80 the actual threaded hole is there so I will be using it when I put the battery back in.
LEL
PLS HELP  A  NEWBIE
how do battery hold-downs D1FZ-10718-A and D1FZ-10718-B  differ? pics pls!
How does either one attach to the fender.... use the square hole with a captive nut? Anyone used  a weld-in cage nut 5/16 x 18?
Thx,  LEL
