Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
Date: 09/15/2019 12:38 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
Date: 08/30/2021 03:20 pm
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
71-73 Hood
Date: 12/07/2018 06:22 pm
Date: 10/14/2019 08:24 pm
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
  • Online today: 1,459
  • Guests: 82
  • Total: 82
catalytic convertor
Started by r4pinto, August 21, 2016, 07:10:00 AM
Well I guess it doesn't matter much. The convertors were hollowed out. Took a look inside when I was examining the pipe to see if it could be fixed where it was rusted out. Nothing in either convertor.
Even if you lived around Cleveland or other areas that require smog tests, that car would be exempt unless things changed the last two years. Ohio has a rolling 25 (give or take a couple) year old limit.
I ended up with the 79 Pinto while living in Akron because the 83 Mustang I was interested in buying would have required the smog test and there was no way it would pass without lots of work I didn't have the money for at the time.
I'm not sure about that year with regard to removing the cats and how it will perform. Newer computer controlled cars tend to run worse without them, at least the newer Fox bodied Mustangs do. You can get them to run better, but if all you do is remove them the cars run worse.
Nope no smog checks in central Ohio, I'm happy to say.
Better check with with the state's smog laws first, if you have to have it smogged gotta have it on there, if they don't see it they won't even run it and you fail.. Some cats are more restrictive than others, I've taken them off and nothing changed, and I've also had to re jet after taking it off, just have to try it and see what happens.
If they are on I'm not "supposed" to remove them. There are no smog checks though
You live in a State where you have to have them ?
When I pulled the engine on my 1980 I noticed there are what seems to be two catalytic convertors on the car. One under the car, and one off of the exhaust manifold. I didn't want to remove either but noticed there is a hole in the downpipe between the convertor.
The car had a bit of power before the fire so the question I have.... Has anyone noticed a power difference or engine running difference when the convertor is removed from the car?
